Hi all, after 3 years of ownership, I have decided to sell my car. Basically she doesn't get used and am not getting the same joy from driving it as I used to.
I have nearly finished the rebuild after I spun a big end bearing. She now has the following:-
R32 GTR Block
Tomei 86.5mm Pistons with Titanium coated piston rings
Tomei Forged steel conrods
R33 GTR Crankshaft Knife edged polished and balanced
New Main and big end bearings
Trust High pressure oil pump
Trust High capacity sump extension
Standard water pump
Venom fuel pump
880cc injectors
Stage 1 head with HKS camshafts
R34GT-R 18" rims with brand new Potenza's
Stainless braided brake lines
I also have a brand new oil cooler which has not been installed yet, a set of coil overs which have not been installed and I am about to purchase an AEM ecu to replace the chipped one it currently has.
Also I have recently installed (last 25kms) a set of Garret turbo's
If anyone is interested pls note that the car is in Gibraltar, and would have to be picked up form here. Pls pm me with any questions you might have.
I have spent £32k in the last 3 years so I am open to reasonable offers.
regards
Ivan
R32 GTR Block
Standard water pump
Venom fuel pump
880cc injectors
regards
Ivan
