821 - 840 of 951 Posts
Super Moderator
Discussion Starter #822
I'd be interested too. I used the stuff all the names mentioned above recommended, but it hasn't worked frankly.
I'd be very interested to see the current condition of the majority of "restored" Skylines currently in the UK.
Yep some of them are proper minging
I've been using waxoyl and now Dynax (which is supposed to be better) for fighting rust on all my cars for donkeys years now on Granadas, Senators and for the past 19 years on Jap cars that I have had and have, Mitsi Galant, Scoobies, and presently 24 year old Lexus LS400, Skyline 33GTR and Stagea.
The difference between the Lexus rust wise and the 2 Nissans is clear, they are greys and the Lexus isn't, although the 'official' imports from Japan are better coated underneath the Lexus is a constant fight - but it is 20 odd years old! I get the garage who services all our cars to respray waxoyl/Dynax on the underside and chassis members yearly. The Nissans because they haven't been subjected to the salty UK roads till they were imported, (the GTR stays in hibernation from Oct to April) are still very clean, they also get a yearly treatment and are presently still clean underneath.
I agree that brackets etc. seem to be susceptible to rust but it seems to me that the thin paint finish is also to blame as well as 'dirty' steel as when I have wire brushed these components down, applied rust killer, painted with Hammerite or similar and then applied Waxoyl it does seem to work better.
The underneath of a car is a very severe environment with driven dirt, salt taking it's toll on any paint or anti-corrosion finish.
A Rust prevention Modification not a Restoration....
Hmmmm....That's a real sticky can of worms and frighteningly grey area Mook!:nervous:
True Restorations are when you take back a vehicle to its absolute original condition as made by the manufacturer when it was brand spanking new. This means original coatings (zinc plate etc), old porous factory sealers, paints and genuine OEM Nissan parts only. If Nissan didn't do it or fit it, The car cannot have it... As simple as that!
Where as what the majority of the Skyline Owners do (myself included here from what I've seen of project threads here on the Forum) is really a rust prevention modification for Our UK climate by using new steel (where and when required), modern paints sealers and other rust inhibitors along with stone chip products, sound deadening sprays and other under body coatings with new poly or other uprated bushings and extra chassis braces too!
I'm sorry to be so pedantic Mike but I honestly only mean to be didactic here by showing people the actual difference between a true vehicle restoration and most peoples rust beating project conclusions. I mean, Who in their right mind isn't going to paint and protect all the parts that Nissan didn't back in the 1990's?! And sadly there are a lot of these vulnerable areas when you start pealing back the plastic guards....:(
So, My type of acid etching efforts above are not a restoration. Its more of a modern under body refresh interpretation anyone can do that will hopefully allow me to keep rust at bay and enjoy driving my Skyline GT-R until they start banning Our terrible cars outright in the early 2040's for strange environmental reasons.
JM2PW!
Is the owner of ‘The Borg’ still on here? That restoration must’ve been nearly ten years ago now, be interested to see his underside. If he’s driven it that is.
Administrator
JM2PW!
Pedantry excused. ;) Restored was perhaps the wrong word but I’d be curious to see the state of many of the cars that have had many thousands spent to treat and prevent corrosion, a few years down the line. Toni’s is a fine example of someone spending the right money, on the right things only for it to have ‘failed’.
Having gone back through some of the pics it looks like Toni's car wasn't really prepped properly before any products were applied. It appears it was just brushed down then POR15 applied over the top- really does need to be taken back to metal and prepped properly. When you just apply over the top as has been done here the rust will come through
Such a shame as so much has been spent doing it
Super Moderator
Discussion Starter #830 (Edited)
It was taken back and treated then POR15 applied. I simply haven***8217;t put up all th photos. I don***8217;t think it***8217;s sufficient though. Basically I wouldn***8217;t do it this way again.
It***8217;s not bad as I said, I just kind of expected it not to be rusting, again!
Super Moderator
Discussion Starter #832
I think even if you***8217;ve had a car ***8216;restored***8217; you have to assume it***8217;s an ongoing process unfortunately.
I disagree on this one. On restorations it is easiest to say, put back to original.
Restorations arent simple as that.
While restoring cars there are possibiities where you are allowed, and can make better then new.
Also there are some parts on the car where you can do whatever you want.
Just one example is a jaguar e-type S1 we are restoring at the moment.
To avoid making mistakes i took the JCNA rule book :
https://www.jcna.com/library/concours/Rule Book/Rule Book Contents Only.pdf
To keep it short it says :
2. Judge's Posture
Judges are permitted to stand, bend over at the waist, or kneel to inspect judged items.
This basicly defines what the judge will see and rate and what not. This gives you the opportunity to do a decent underfloor protection on the car below the visible line. Still most of the owners will have no underfloor protection, as they see the car as an investment, and want it to stay factory look as much as possible to avoid problems when selling.
I dont think there are clear guide lines on how to restore a skyline at this moment, as it still needs a few years to become a real classic. If it becomes clear you will know what needs to be put back to standard, and what is left to the owner to decide.
The route i would go with a Skyline is enjoy, drive, take care of. If im concerened about future value, stash oem parts to be able to reinstall them if it increases the value in future.
Im sure doing a decent underfloor protection wont lower the value of the car.
I tend to disagree with that.
My expectation would be to see some corrosion on fasteners, bracket edges and similar. The reason is they are thin material, and it can allways happen that there was a human error in plating or spraying the protection. That should happen within the first 2 years.
After that i wouldnt want to see any new signs of rust for 10 years, if the job was done right. We have to take into count that materials used for restoration advanced alot in the last 20 years.
If rust happens earlier there is a good chance that standards and rules werent followed. For example a sheet metal was welded but insuficient care was taken to protect the welds from the inside which are hard to get. People dont use a boroscope camera, after waxoiling sills making sure everything is protected etc.
Also if some signs show, which is allways possible my expectation would be for the firm to look into it, see if it is normal or a mistake of the job they did. If its a mistake i would expect them to take care of it free of charge.
Where did these guys go wrong? - https://www.gtr.co.uk/forum/113131-rips-rebuilds-borg.html
Less than ten years later and it was in for strut top repairs...again. Sadly all of the photos have dissapeared from the thread but i remember it being the most meticulous restoration i had ever seen. Rob isn't known for cutting corners or doing a 'bodge-job' either. It seems no matter how much money you throw at these cars the rust just keeps coming back.
He didnt cut the struts open to have a look, and from the outside they looked ok.
He told the owner about some additional expense (struts), and the owner didnt want to know about it already paying to much in total for the project.
There are a dozen scenarios that could have happened, and all are unimportant. They can lead you to wrong conclusions.
Most important thing about this type of work is a torough initial conversation. Which from my expirience isnt to popular, as a owner wants to hear what he wants to hear.
If he doesnt hear what he expected, there is a good chance he will take his job elsewhere, which of course is ok. We know this to good in situations where we sell, not where we are costumers and own Skylines.
After that it is meeting the expectations. At this stage some firms decide to go with a low estimate, they promisse, they make it simple, they dont discuss detail, they dont talk about expectations, and adjust pricing to those expectations.
After that, there are 2 possible routes.
a) they meet the owners expectations but it often costs double then quoted
b) they adjust everything to the initial budget and everyone is unhappy about the end result, work and profit.
Since it is a open market, low estimates give you a possibility to accumalate work, and it is hard not to give in to such tactics. Out of this strategy you sometimes work without profit, you lower your standard to meet delivery dates or pressure from the owner etc. In a long run this type of bussines wont last forever as it is not on healthy foundations.
Handing out realistic estimates, if you arent already the top place to do such jobs, will lower the rate you get a contract from 70% success to 20% success, so you have to stick up with it. What you get in return is less stress while working, less pressure from owners, less change from the initial estimate, maybe 10-20%, with photos, documented (unforseen work), and you are allways able to work to this high standard you defined with your pricing.
Every job and people doing it are similar. Its up to the owner to decide which style suits him better and jump on that train. Its to bad that we as consumers jump on to many offers that are to good to be true.
Super Moderator
Discussion Starter #837
Yes but that wasn't me. I made it very clear there was no budget and I wanted the best done for the car that I could. I didn't go with where I went because they were cheaper, far from it.
Administrator
so, out of curiousity, assuming a car has been taken back to bare metal, acid treated or whatever it is, then the protection applied correctly, what sort of "life" should that have on a car being used on a regular basis?
Wasnt pointing at you Tony, im watching your threads and know your standards. I just got carried away explaining why such jobs fail :chuckle:
You know its hard to say, and noone knows for sure. If i had to do some pubtalk i would say life expectancy of a car is 15-20 years from new. When restored this would be reset to zero. I would expect another 20 years + if the job is done right, and the car is used dialy. Within this 20 years there could be some signs, but there shouldnt be any major repairs, if its not human error. After this additional 20 years of use i would expect the car to be in a much better state then it was when 20 years old.
When repairing a shell it is a smart thing giving it to a specialist, someone that really has expirience with those types of cars. Most of the shells have rust because of design flaws or lack of protection. Someone with expirience will get all the work done and take care of all additional spots that could make trouble in the future.
Like said before rust after a restoration if a car is seam sealed and protected as it should be, waxoiled and welds protected should hold a long time. Also you have to be carefull that all bodywork is done right, that the shell is able to "breathe" meaning you didnt make some pockets while repairing, that are suitable for moisture to build up from inside and start the process again.
