Can you help with this software problem?
Eighteen months ago, I upgraded to Girlfriend 1.0 from Drinking Mates 4.2, which I'd used for years without any trouble. However, there are apparently conflicts between these two products and the only solution was to try and run Girlfriend 1.0 with the sound turned off. To make matters worse, Girlfriend 1.0 is also incompatible with several other applications, such as Lads Night Out 3.1, Football 2 and Playboy 6.1.
Successive versions of Girlfriend have proved no better. I tried a shareware beta-program, Party Girl 2.1.The learning curve is easy and the user interface for Party girl is very accessible but the program had many bugs and left a virus in my system, forcing me to shut down completely for several weeks. I guess that multi-user applications should be used in conjunction with a firewall.
Eventually I tried to run Girlfriend 1.2 and Girlfriend 1.0 at the same time, only to discover that when these two applications detected each other they caused severe damage to all my hardware.
Sensing a way out, I upgraded to Fiancee 1.0 only to discover that this product has to be upgraded to Wife 1.0. I did this largely because, whilst Wife 1.0 uses up all available resources, it does come bundled with FreeSex Plus and Cleanhouse 2000. However, I discovered that Wife 1.0 can be very unstable and costly to run. For example, any mistakes I made were automatically stored in Wife 1.0's memory and could not be deleted - they then re-surfaced months later.
Wife 1.0 also has an automatic Diary Explorer and E-mail porn filter, and can, without warning, launch Protostrop and Whingezip. These products have no help files and require you to try and guess the problem yourself.
Additional costly problems are that the Wife 1.0 bundle, which came with the original system, needs upgrading regularly, requiring Shoe Shop Browser Pro for new attachments and Hairstyle Express which needs to be re-installed every other
week. It also conflicted with some of the new games I wanted to try, stating that they are an illegal operation. Wife 1.0 also has a rather annoying "stay resident" pop-up called Mother-in-Law, which cannot be turned off.
Recently I've been tempted to try Mistress 2000, but there could be problems. I'm told that if Wife 1.0 detects the presence of Mistress 2000 it will delete all MS Money files before un-installing itself.
Any info that may help would be greatly appreciated.
