Well,
My gearbox started to act a bit strange lately on my MY09 and I assumed that my solenoids are getting dirty and that it was a matter of time when I will get stuck with just odd/even gears...
I had my solenoids and magnets cleaned (I am near 50.000 km now) and replaced the transmission fluid with Willall WR35TM.
The result is amazing - it is a new gearbox! :clap: I forgot that this gearbox is so fast...:runaway:
N to 1st or Reverse is smooth as butter and gear change while driving is significantly faster...
I know that this improvements are not due to gear learning cause I have done it with my AP several times when my problems started and it had no influence on this performance...
I just actually wanted to give the advice - don't wait till your gearbox gets stuck, do this solenoid cleaning on every gearbox oil change...
And special thanx to vex_sb from this forum, for the way he takes care of all the GTRs in Croatia
Guys from the region, if you want good service, come to Slavonski Brod and give your car to Vedran
