Had a fright today.....booted the car from the lights whilst out for a blast, and it was popping and missing all over the place after 3000rpm. OH MY GOD thought I!!! I then discovered that this would only happen when the boost was set on "high". Must be a fuelling issue I thought......so pulled over to check it out.
Here's the advice..... If this happens to you then check the hose that goes from the inlet manifold to the Fuel Pressure regulator. Mine had blown off the manifold, probably because I've been spraying some oil around in an attempt to find the airleak I've got.
The air leak has got worse by the way.....ticking over at 1400rpm now!! I've bought all the bits from Middlehurst, so I think it's time to start stripping down the inlet bits and pieces!!!!
Regards
Regards
