1 - 7 of 7 Posts
Anyone found a good product to put on the pipes to prevent soot build up or at least make it easier to clean off? Only takes a small run for it to build up after a wash!!
I use the same wax I used on my rims from poorboysworld. Don't expect miracles but it helps.
Real men use a H-Pattern.
Look in Traders section.
Ask Alex at Serious Performance for advice. He's the man.
Optimum Opti Seal or FK1000. Booth hi temp sealants, i've used booth and found Opti seal is easier to apply but requires a little more buffing if you spray too much on. Took mine off and gave them a few good coats, still rinsing off pretty much (tho i don't do a lot of miles :eek:) Speak to Alex as Moleman said, he will sort you out :)
Serious Performance Non abrasive Paint Cleanser to remove the soot safely whenever needed and as others have said, just keep topping up the wax / sealant so that it should make it a bit easier to clean as well as protecting the paint underneath.
1 - 7 of 7 Posts
