Hi guys,
My Gtr has only one key as the previous owner has misplaced one.
I believe I should be able to buy one online at some point and get nissan to reprogram for around £60 ish???
My main concern was if the missing key falls into the wrong hands? Is there a way that the missing key can be deleted from tne car so it will no longer be able to connect and operate?
The reprogramming should prevent the missing fob from connecting with the car but the actual manual key inside the fob will still work unless you change the locks
Ok - so Will i have request that Nissan remove all keys 'not present' from the cars ecu or will this be done by default when coding the new key?
Also - would anyone happen to know if a MY09 key can be coded to operate a MY11? Or are the keys totally different? (They look the same) asking as there is a MY09 one cuurently on ebay?
