1 - 10 of 10 Posts
Brought a set of spark plugs the other day, NGK Greedy 8's (no: T7341-8), previously fitted were NGK (not Greedy stamped) No: R7434-8. Question is are these basically the same plug? both were supplied by well known but separate tuners.
The other shocking thing was the price approx £120 for the 6, just tried Spark plugs.co.uk and they quoted £160:eek:
There must be a cheaper source for the above anyone got any leads to where that might be or do i put this one down as another joy of Skyline ownership.:(
Those are the super-duper racing plugs, as recommended by our own tyre-encased Mines-sceptic UKDM Ford whore SteveN :D
And yes they're about £20 each :(
Personally I use NGK BKR7EIX, £50 a set :D
You don't really need an NGK Racing plug unless you have a high powered car.
The "standard" NGK Iridiums are fine in most cases.
Discussion Starter #4
My car's running about 600Bhp ATW, would you say yes i need the tip-top racing plugs or okay with normal iridium's?:)
Your at the thresh hold. If you use the performance regular then Mick is right, if most of the time you are commuting, save a set of the good plugs for when you plan on using the car in anger!
You almost certainly should be using 8's, 7's are on the hot side.
I have the 7434-8's for normal and -9's for those more enthusiastic times.....
Well said.
600 ponies , BKR8EiX's (from £50 local Bennets) , been in ages , lasted much longer (in my car) than any of the mega buck plugs ive used in the past .
Probably change to BKR9EiX's when its remapped for more boost soon :)
other people's experience's may differ :)
I ordered 12 plugs last week from www.ngk.com
Fast delivery, good service!
In Norway these plugs would cost about 20GBP each.
I got them for about 4GBP each :eek:
Just type inn the plugnr and it will show up!!
Thank god for the internet!! :D
1 - 10 of 10 Posts
