A personal note is that I will steer away from Denso/HKS spark plug.
The main reason is that the iridium on the Denso plug is very small, and have had problem of breaking off and destorying an engine. It is very good if everything is running perfect. But then all it takes is a leaking intake manifold gasket to finish off your engine.
I will go for NGK/Trust plug. Sadly, NGK only do up to grade 7 for the GTR fitment as far as Iridium goes. You really should go for grade 8 for a GTR. But at the same time, if it is only stage one, I don't see why Grade 7 won't work (after all, standard is grade 6 in a GTR)
Just my 2 pence worth.
