Since fitting these Spitfire coils, my car has a high load missfire. The STD coils didn't do this. Do I need a different plug gap? They are 0.8mm at the mo.
looks like one guy earthed just about everything in sight (ignition amp, and coil pack mounts) directly to the battery. The ignition amp lead is a pretty frail looking piece of wire. It could be broken or intermittently connecting in the loom under all that insulation.I've already cleaned up the earth wire on the transistor pack.:nervous:
I'l try a smaller gap, but I really can't see that being a problem.
:bawling:
