1 - 6 of 6 Posts
Noisy brakes are not normally the kind of thing i would bother to complain about but the one's on my car put a double decker bus to shame.
I assumed it would probably wear off after a few weeks but i was wrong! It only does it when you are driving pretty slow like pulling up somewhere but if its on a night it will wake my whole estate up im sure.
Anyone know why it is doing this and more importantly how do i stop it from doing it?
Administrator
very common.
obviously a bit of copperslip helps, but its also down to the type of pad etc.
only real way to stop it is to choose a different/tried and tested disc pad combo
afaik
mook
Ok cheers for the info. Guess i aint the only one with the problem then. Maybe i'll look into some new pads and at worst disks too.
Rattling twin plates and squeeky breaks do nothing for the image :p
Administrator
i fitted new pads a while back, bedded em in properly and all was silent...
but just recently, the squeel has returned.
i quite like it now, brakes are for stopping, who cares what noise they make.
besides, if i lived on a estate, you wouldnt hear the brakes for the exhaust note ;)
mook
Hehe, good point. mine is rather quiet at the mo as it has a racing cat on it still. Maybe i should just remove that to drown out the squeel ;)
Re-faced my V spec R32 discs and bunged Ferodo DS2500 (I think) pads in. After 200 - 300 miles of bedding in, they squeal like biatch on a banshee. This is mainly at low speed, medium to semi hot as the more I thrash her, the better the brakes = no squealing.
After coming from FCUK ALL brakes to preety decent gear now... I anit bovered AT ALL wot noise she makes!!
1 - 6 of 6 Posts
