Hi all.
I have a new set of id1000 injectors. Which only come in 11mm. From what I've read, to fit them into the standard 10.5mm fuel rail, it needs to be drilled out to 11mm.
However I have just test fitted one, and it fits in the rail fine, fair be it a little snug.
Has anyone else squeezed them into the standard sized rail? Or does it need to be drilled out?
I managed to fit id1000 into a standard rail, it wasn't easy but they went in. I pushed them in and had to cable tie them to the fuel rail or they would jump out. Then once all 6 were fitted and the rail was bolted to inlet manifold cut the ties off
Hi all.
Mine popped in like a shilling in a sheep's a**. No problems, no leaks.
