1 - 7 of 7 Posts
Any idea what to expect on 102ron fuell
And what boost will the car hit ?
Mods are
Exhaust downpipes ecutek inj fuell pumps
Air filters
All info is Welkom
Adding 102 Ron fuel will have no effect on boost , unless the ecu / boost controller is reprogrammed to raise it
If Will Be mapped on 102ron
Your car is stage 4 already the standard turbos will almost be maxed out so if you want to keep them safe I wouldn't expect more boost from the update map, with the higher RON rating your will be able to run more timing.
Ok understand
Then specv turbo's might do The trick
Or mabe e85 fuell
Is This ok on stock turbo's ?
The main problem is torque with out doing the rods you can only gain bhp and not much with std turbos.
1 - 7 of 7 Posts
