Often we hear owners complaining about the quality of their Stageas Automatic Transmission when shifting through the gears, most come from everyday drivers who simply can't stand the constant slipping and flaring between the gears some just want a faster sharper change or there adding more power and need to know the transmission can take it . We have had dozens of owners contact us about improving the transmission in some way to overcome these problems without going down the expensive swap to manual transmission that so many stagea owners do!
We have come up with a cheap and easy way to turn your Stageas transmission into a nice firm shifting transmission without having to remove the transmission from the car, Simply remove the old valve body and fit one of our Re calibrated Extreme Nissan Valve Bodies.
The valve body comes with instructions for the removal and refitting of the new valve body. The valve body has undergone a tremendous amount of testing and in every single case the customer has been quite overwhelmed about the difference the New Valve Body made to the vehicle.
The transmission once fitted with the new valve body can easily handle more than twice the power and torque with nice firm shift points (At time of print the valve body had been tested to 607Hp = 450Kw without failure to the transmission).
Kit contains.
New Shift kit valve body & High performance servo.
Up rated shift Kit with shipping to the UK £659.78
Kit contains.
