1 - 6 of 6 Posts
Went to Starperformance 4X4 rolling road shoot out today
Enclosed a copy of today's rolling road sheet for my car.
383 bhp & 299lbf-ft of torque @ around .9 bar of boost.
Anyone got a dyno sheet of similar spec for me to compare?
TIA
Charlie.
Discussion Starter · #2 ·
Keith's Dyno Sheet
Keith asked me to upload his dyno sheet.
He hasn't paid his phone bill, so he can't
get a connection.
Hi Guy,
Keith can't get on line at mo'
Rod Bell fitted HKS 'step one' cams last week.
HKS Adjustable cam wheels and set up the valve timing,
then spent the best part of a day mapping Keith's Apexi.
another dyno-sheet
Here's my dyno sheet from Star Performance for comparison. Compared to Charlie's, my car doesn't seem to come on boost so fast but has a similar peak power figure. I took my car there having been told by the dealer I got it from it was totally standard (I've only had it 3 weeks). As you can see it obviously isn't standard, running about 0.9 bar with a Middlehurst-modified ECU. Saved me a bit of cash as I was planning to take it to this spec.
dyno day
hi back on line again worldonline cut off my server back to normal
now. over the moon with my car now it has so much mid range torque and just keeps pulling all the way to the rev limiter.
guy on your old car you had 600cc injectors fitted what ecu was it on before you fitted the hks f-con to get 452 bhp with the same cams as i have and what was the reason for going for the big injectors at that stage.
thanks keith:D :D :D :D :D :D :D
Guy,
What was the spec on your old engine?
Was it HKS cams.etc.
Have you a dyno sheet we can compare figures?
Cheers.
Charlie.
1 - 6 of 6 Posts
