hi
this is taken from my engine rebuild guide on skylineowners.com
at this point its a good idea to recon the starter motor.......they seem to be quite a common fault on the RB's and TBH i have never come across a starter that didnt need anything else other than a good clean out to get it working spot on for the next 10-20 thousand miles
it is possible to do all of the work from below the car, even the top starter bolt is possible with a short spanner (they are 13ml BTW), its also possible to remove the starter from below too, remove a few bolts to the left of the pic and pull it through...
as mentioned the starters became intermittant and when they play up you would just hear a click but no cranking...this was always likely to be down to crap stuck in there so im just giving it a general cleanup and fingers crossed it will work fine after
remove the two 8ml bolts
and then pull the bottom carefully off
removing the rotor is just a gentle pull
again same with the case
spot the ball bearing....it sits on top of the shaft (bearing inside spanner C)
The solonoid screws do not want to come out, if one (or both!) round off you can remove the heads and remove the studs with pliers or whatever and replace
with the solonoid off the top part will now come apart
i used WD40 to clean the moving parts and isopropyl alcohol on the electrical parts
fully stripped
top parts cleaned and ready for refit
the bottom part is real easy, use electrical screwdrivers or welding wire etc to hold the springs back behind the carbon brushes on the bottom part of the unit and push the rotor carefully in before removing the screwdrivers
then fit the rotor into the housing
the top part is easy too, just remember to put that bearing back on the top of the shaft before they go back together
so back in one piece now then!
to test the starter just rig it up to a batterey...a charger wont really have the juice for this
the solonoid should shoot the cog forward and the main live on starter should spin the cog
fully stripped
