1 - 6 of 6 Posts
I have just purchased a gts and have been told that the turbo internals have been replaced with steel ones. There is no paper work to prove this, is there some way I can tell just buy looking at it?
Also the car is presentally running 325bhp atf what size are the standard gts injectors and when do I need to change them?:squintdan
Apart from someone driving it and being able to spot the characteristics the otherway is (get someone) to drop the down pipe and get a mirror up there to check the turbine wheel.
Worked for me...always thought mine was a bit laggy and then it was confirmed that the internals were, indeed, steel. Always a bonus...
mine too - they wouldn't really kick in until 4000rpm. Turns out they were steel rebuilt. I know because I took apart my entire engine.
Do not run them at 2 bar.
1 - 6 of 6 Posts
