I have just purchased a gts and have been told that the turbo internals have been replaced with steel ones. There is no paper work to prove this, is there some way I can tell just buy looking at it?
I have been told that I can drop the down pipe and use a mirror to look at the turbine, what should I look for (steel blades?). Also how can I tell if the exaust elbow is standard
Also the car is presentally running 325bhp atf what size are the standard gts injectors and when do I need to change them - 350bhp?
thanks Dan
