had my steering rack bushings and steering column aluminum bushing installed today. The steering rack took about ten minutes to swap bushings (no luck in finding aluminum bushings, so I used Nismo.
I didn't see the column bushing install as I had to run to work, but the mechanic told me it was a piece of cake. I had step by step instructions with pictures printed just in case, but he didn't need them.
My rack bushings were totally shot, and so was the column bushing. And all this time I thought my car had quick steering. So now, the sum total of my steering mods are pillowball tension rods, tension rod brace, and the solid column bushing. I can yank the car hard enough to actually induce a bit of body roll - I've NEVER felt my car roll, ever!!
The other thing is that my car now tracks dead straight - I think with the play in the system before, that led to the car tending to hunt around a bit. And...on the roads where my car would tramline the worst...it's now a simple matter of holding the steering wheel and the car sails through.
Which leads me to wonder - how many tramlining complaints could be traced to steering bushings (and not necessarily suspension settings)? Because camber and toe hadn't been touched, the worst roads in Seoul are so deeply grooved even my bikes don't like them, and I feel like I've just been handed absolute control over the car, regardless of surface. Yes, I can very clearly feel the road, but the wheel doesn't buck and twist anymore (I had suspected that with tightening things up, tramlining would actually get worse).
Well, that's one more system of the car I've got completely sorted. I just regret a bit not getting aluminum bushings (which would last a lifetime) versus the Nismo units, which will eventually wear out.
