you will need 10mm socket set, sharp knife and some guts
taking off the old one, need to remove lining in the boot etc
pull off the circluar painted things under each edge, 10mm nuts
need to replace the sticky stuff, don't forget the nut at the back
a bit of string to help with cables
pull apart carfully as you will reuse the filling
sticky patch's take some removing, used masking tape to protect paint. left the nearside upright to save having to remove sticky patches
unscrewing the middle support to take out brake light
Remove panel to take out strut
Original compared to the carbon one, both very light
using string for cable treading
Wing on rear, sorry pocket camera, really need polarized filter
