i would like to keep my stock wheels because i like them.
but they look to small on the skyline. i thought some spacers would help here.
does anybody know which one to choose? 25mm for each wheel?
and which size of the centre bore?
are there any pictures from 34´s with oem wheels and spacers??
thanks
but they run 10x18 wheels with et12, so if i calculate 1/2 inch (12,5mm) to the outside and 18mm from the et the wheel should be 30mm closer to the fender.
front 20mm, back 25mm if i calculated correct??
do these spacers hold 700hp without breaking?
i guess i will take german H&R spacers.
i have some 25mm from my supra here, i have to get the centre bore a little bit bigger and will try them, but im not sure about the size, will try it and post some pictures
