Hi guys!
I have completely taken my engine apart and during this process, one of the plastic things on the front of the injector just snapped off.
What can I do about this? Is there any replacement or should I get a used stock injector?
Next question would be if there are some uprated piston rings for the oem pistons out there as I will not be uprgrading the pistons and rods any time soon (probably for the next two years) but would like to go to 1.2 bar or slightly higher (I know that stock turbos are not capable of this)!
What's the best place to get acl main bearings, arp main studs and fluidampr (not the ross damper) in Europe?
Thank You!
Kind regards,
RoB
Thank You!
Kind regards,
RoB
