Since there are not much GTR's in the US I wanted to see if you guys can help.
My R33 has a R34 motor swap on it, ECU and wiring was swapped out also. I've had the car for about 2 months and I feel the car is a pig, (sorry to say), I've had Eclipses (2 door Evo's) with intake and exhaust and the car pulls much harder then the R33. Full boost doesn't seem to come on until 3600 rpm, the car seems to run rich (I think it's due to the HKS SSQ's)
Current mods on the car is:
R34 Swap (3000 miles on the motor)
HKS Down pipe
ARC Ti 100mm exhaust
Mine's intake
ARC Catch can
HKS SSQ
There are no boost controller and everything else is stock.
Is slow spool normal on the the R34 motors?
Lastly I got a good deal on a Greddy R-SPL HG, 302x710x165, would you guys recommend to put this on with the following set up (see below) or wait the my next setup a 2.8 (going in about 1 1/2 months from now)
HKS GT2530's
HKS 272's
Nismo drop in pump
720 cc injectors
HKS or Tomei Fuel rail
SX FPR
HKS Hard pipes
ATTKD Ti extension housing
ATTKD Ti Down pipes
AEM EMS running on Map
Thanks in advance guys!
John
HKS Down pipe
Mine's intake
ARC Catch can
HKS SSQ
HKS GT2530's
HKS 272's
Nismo drop in pump
720 cc injectors
SX FPR
HKS Hard pipes
ATTKD Ti Down pipes
John
