Hey guys, posting up for a friend real quick. His clutch stopped working the other day and when I came to take a look at it, this is what I saw with the clutch pedal.
Any help on how to fix would be greatly appreciated!
Cheers,
Dylan
Assuming the clutch hydraulics are all on the car, check the clutch master cylinder reservoir and you will probably find there***8217;s no fluid.
You most likely have a leaking clutch slave cylinder or master cylinder. Find the leak, replace seals, bleed with DOT 4 fluid and you should have your clutch hydraulics working again.
All the hydraulics are on the car, and there's no leak visible to us. I know for a fact that the clutch pedal is moved out if normal position when comparing it with my own GT-R.
Sent from my iPhone using Tapatalk
You need to find out what's snapped/ broken. If you pull the pedal left and right does it move?.
Has the servo/ master cylinder come away from the bulkhead (or is the bulkhead torn where they mount?).
Somethings failed that mounts the pedal/ pedal bracket.
