1 - 6 of 6 Posts
Hey,
With air conditioning on, is it normal for AFRs to alternate between a few values.
  • With no air con on, AFR sits at 13,9 due to being happy with cams.
  • With air con on, AFR sits at 14,4 but then will jump to 15,5 then back down again
I find this strange but there is definitely a noticeable change in engine sound when this occurs.
Thanks!
Sorry buddy, it's an Apexi ECU.
F/C A.E 1100
F/C E/L 1100
F/C A/C 1200
Idle A.E 950
Idle E/L 1000
Idle A/C 1050
Idle ??? 850
Drive-ability is splendid, just very wacky idling. It doesn't cause any stalling so I'm just being a typical perfectionist and monitoring the values.
Skyline Section Manager
At what rpm does the TSP idle switch off?
My INJ vs TPS is set at
82, 71, 60, 50, 40, 37.9
I can't see any other settings for the throttle that would manage fuelling
I guess my main query is whether it's actually a mechanical issue, i.e. need to clean the AAC or whether I've just got a few idle problems in the map
1 - 6 of 6 Posts
