161 - 180 of 184 Posts
Just found your thread and I have to say, BEAUTIFUL car! Red suits the R33 very well! Which color code is it?
And next question, which lenses for your headlights did you used?
Discussion Starter #170
Some changes for the 2019 :D
ITB and Greddy plenum is out and say hello to Veilside intake manifold + DBW from N62 v8 engine. Injectors Delphi 1000cc + Walbro 450LPH. Ported & flowed head with HKS valve spring set. And Kansai Service tower bar ***10084;***65039;
We will see the difference on the dyno and in real life.
Discussion Starter #180
Engine:
*CP Pistons
*Bridgeway H-Beam rods
*JRSpec GTX3582R BB turbo
*Custom Twin Scroll exhaust manifold 3mm thick stainless steel tubes + HKS gasket
*Tial MV-S wastegate + water cooling
*HKS SS 264 8.7 cams
*Ported head + HKS springs + Cometic 1.5mm
*ARP head + rods studs
*King Racing bearings
*Nitto oil pump*Intake manifold VeilSide + DBW BMW N62 + accelerator pedal 350z
*Emu standalone + MAC + BT + DBW
*Ross Tuffbond Harmonic balancer + Trigger KIT
*Delphi 1000cc injectors
*Billet fuel rail
*Tomei Type S fuel pressure regulator + Tomei gauge
*Walbro 450LPH HP fuel pump
*NGK BKR8EIX sparks
*Radiator 52mm
*Spal VA09-AP12/C-54A double fans
*ATS Triple Carbon Spec I clutch
*AEM 21-3059DK air filter
*Precision 600x270x95 intercooler
*HKS SSQV V1 blow off
Exhaust:
*Custom stainless steel 1.5" screamer pipe + stainless steel reinforced exhaust flex pipe
*Custom stainless steel 3" V-band downpipe + stainless steel reinforced exhaust flex pipe
*Two stainless steel V-band center sections + Magnaflow muffler [11249]
*HKS Priest back box
Suspension:
*MeisterR Zeta-R coilovers
*Polyurethane full bush kit front/rear suspension
*Galvanized bolts and nuts
*Cusco rear camber arms
*Japspeed front upper camber arms
Braking System:
*Brembo 6pot front calipers + 360x30 disc from IS-F
*Akebono 370z 2pot rear calipers + 350x20 disc from 370z
*Brake pump BM50
*Tilton brake valve
Exterior:
*Car painted in Jupiter Red from Mercedes AMG
*Volk Ce28 18x10.5j +22 [rear spacer 5mm + 15mm in front]
*Hankook Ventus S1 Evo3 265/35/18 tyres
*Kics R40 iCONIX wheel nuts
*Bixenon LHD
*Fender Washers
*Auto Select Devil Wing
*Nismo rear wing end covers
*Nismo clear front indicators
*Nismo clear side indicators
*OEM spats R33 GT-R V-Spec
*Carbon cooling panel
Interior:
*All stock seats, no rips or tears, all in great condition
*Indyvidual LHD velour mats
*Dashboard cuscom from s14 and r33
*R34 steering wheel + EVO3000 mod
*BMW M custom shift knob
*Black alcantara roof liner and sun visors
*S15 black rear view mirror, room lamp, map lamp + white led
*Cusco rear strut brace
*Kansai Service tower bar
*Defi Link Meter BF 60mm DF04301 + Control Unit II DF05002
Audio:
*Headunit 7" Android 9.0 Octa Core station
*Front speakers - Morel Dotech Ovation 6
*Amplifier Emphaser EA 4100-500
*Subwoofer Gladen SQX 12"
*Speaker cable - Prolink OFC PRO CAV1003
*Signal cable - Prolink Futura FTC101
*Soundproofing [bulkhead, dashboard, floor, roof, rear fenders, doors, c-pillar's, rear deck, trunk] - Dynamat SuperLite + foam GMS 3mm & 10mm
*Bosch S5 74aH
