After a 9/10 month rebuild following complete bottom end failure my GT-R33 V-Spec is alive again. Now at a bit of an en-passe; MOT required but engine not run in so emissions due to un-run-in engine dire and way over.
However, more of an immediately pressing nature is the 12-1600 rpm hunt/surge which repeats every second rhythmically/consistently. The cold-cycle idle is solid and clean, but once out of closed loop...Due to my 1000cc injectors you can hear clearly the brain trying to work it out. Essentially the tick of the injectors taps out the increase in revs then they cut "silence..." and the revs drop to 1.2k before the cycle picks up again tick...tick...tick... 1.6k" etc...etc..and so on.
Picks up clean on the throttle.
Trouble is the MOT analyser cannot get any reading because this is way above the range expected.
I've narrowed it to.
1) Idle air controller
2) Vacuum leak
3) Intake leak
4) AFM
Is this a reasonable assessment?
Smoke testing intake side to check for leaks. Same with vacuum. Cleaning of AFMs/ AIC...Most likely cause of this out of the options...?
J2K
2) Vacuum leak
3) Intake leak
4) AFM
J2K
