i have a few questions about the skylines suspension and steering which im hoping you guys might be able to help with.
firstly does anyone have any spring and damper rates for the skyline? and are the damper two way. if so do you know how much the rebound rate is?
also how much lock do the rear wheels have when the rear wheel steering is in use?
what is the toe out on the skylines set as?
and finally could anyone give me a little report on how the r34 feels to drive? ie does it understeer, oversteer or is it pretty neutral?
any feedback will be gratefully received.
cheers
hicks.
cheers
hicks.
