Has anybody got any info on suspension kits available for a 95 GTS. The standard one is a little soft and high so I was looking to lower it a bit and make it a little better at cornering as I live in Milton Keynes and spend most of my time turning.
There are loads available - Tein, kg/mm, Nismo, Apexi etc etc. Depends on how much you want to spend and what level of adjustability you want. What I will say is that, from my experience, just fitting lowering springs in isolation will help your low speed handling but screws up high speed handling (i.e. 70-80mph +) so I wouldn't recommend it.
I had NISMO springs fitted to mine. Dropped the car about 3cm and makes it much stiffer. Even though I went for the softer springs it's still incredibly hard. If you go for the really hard setting you'll have no teeth left.
If' you're at the Grasshopper on 4 May you can see for yourself
A forum community dedicated to Nissan Skyline GTR owners and enthusiasts. Come join the discussion about performance, mods, troubleshooting, body kits, classifieds, maintenance, and more!
