Hi, on my R32 GTR I have a set of "coilovers" from Tanabe. They're probably well discontinued now as the current coilovers from Tanabe only fit the R34.
To describe it, the strut itself is orange, with a PRO sticker on it. On the top of each coilover you see a 14 mm nut, going through that nut is a threaded rod with the tip of it rectangular shaped (probably where you mount the adjustment knob on).
I'm not sure how to adjust these things, they make no audible clicks when turning either the nut or the threaded rod - and there are no instructions on tanabe-usa.com
Does anyone with similar Tanabe coilovers have any info?
Thanks!
Thanks!
