I am fitting a big in tank lift pump feeding an external swirl pot, with that in turn feeding two Bosch 044 motorsport pumps. The stock moulded plastic tank top is far from ideal as there's no easy way of upgrading the electrical connectors for something capable of carrying more current, or having proper dash whatever screwed pipe fitting on it. The stock moulded in steel pipe stubs are very small for a decent fuel flow from a hefty in tank lift pump, or an in tabk Bosch 044. I was about to make an alloy top with a plain 4mm thick face to allow me to fit whatever pipe through connectors I need and heavy duty (ATL) fuel proof electric cable feed through glands. Is anything like this commercially available, I know there are ones for the Toyota Supra? If not is anyone else interested in one, if I make one it's a good time to make 3 or 4 of them. They would use the stock rubber seal and outer knurled locking ring. Thanks.
