Hi
i think i used lot of search and did not get clear answer so making a topic...
i have link g4 exterme ecu
race technology dash 2 and logger
stock attesa controller
i would like to get wheel speed sensor inputs from all wheels
can i tap into each sensor or will it scramble the signal for attesa ecu?
i want to use the signal for data logger
edit-i dont have abs controller itself anymore but as i understood attesa still uses abs sensor signals
thanks!
Skyline Section Manager
You can take a signal from the ABS sensors with no ill effect.
Where ever you like. It makes no difference.
