1 - 6 of 6 Posts
i read about people who use te37 wheels with 18x9.5+12. that it may rub.
i saw the endless r34 bayside blue had 18x10.5+ 12. tire size im not sure about.
i checked neweraparts.com and they dont have this size.(18x10.5 +12 )
right now im useing work meister s1 3p 19x10.5+17 275x30x19 without any problem:)
so.. im not sure what size i should go for to not get some conflict..
http://www.gtr.co.uk/forum/118816-endless-r-automesse-700hp-r34-gtr-vcam-sale.html
would be very thanksful if someone other can comment about their experience with same size specifications..
maybe 18x10.5+15 would work fine..?
that is actually the spec for GTR wheels - and I know people running 19x9.5 ET +12 with no issues. Of course, the size of your tires and suspension height will determine how much (if any) rubbing you will get.
Hi
I have 19x9.5 +12 TE37s on my 34, running a 275 tire. Yes the fronts do rub the inner arch's but only on full lock and my driver side does contact the bolt holding the standard dump valves.
This is only on full lock though so it can be avoided without compromising the actual drive- how often are you on full lock!
I think it all depends on how low your car is.
As far as i know 18's will have no trouble.
Hi
i bought te37 19x9.5 et+12 now... a have som brand new 275x30x19 tires from my work meister wheels.. but im thinking about maybe buy som 265 tires now..
thank you everybody for answear this thread.. it was helpful,choosing the correct ofset,, will post a pic of everyhting later;)
1 - 6 of 6 Posts
