1 - 20 of 86 Posts
Here is the new 2006 spec list for my car.
Should be a good racing season
Keith:smokin:
SPECIFICATION
ENGINE
Nissan Skyline GT-R R32,3L OS Giken motor, uprated Tomei oil pump, RB
Motorsport big sump and Trust remote oil filter kit, RB Motorsport modified
oil feed to cylinder head, Mocal oil cooler,RB Motorsport cylinder head Oil
Scavenge Pump system,Turbo Dynamics 1250 bhp GT spec single turbo,Trust
racing wastegate and short dump pipe, Trust RSPL-R 170mm-thick cored
intercooler, RB Motorsport custom hard pipe kit, Trust racing dump valve,
R.B Motorsport 110mm throttle body, R.B Motorsport ultra-large plenum, HKS
300+ degree Step 3 PRO L camshafts, OS Giken 3L adjustable cam pulleys,
Tomei kevlar-reinforced timing belt, Tomei valve springs and retainers, RB
Motorsport-spec modified cylinder head with 1.5mm Oversize IN /EX valves,
Trust 1.2mm head gasket, RB Motorsport fuel rail, 1600cc injectors, New
Bosch 044 external fuel pump system,uprated fuel pressure regulator,
12-litre alloy fuel cell, Trust OS 3L exhaust manifold, RB
Motorsport-modified 5" exhaust system, Trust uprated radiator, RB Motorsport
modified cylinder head cooling system, Autronic SM4 engine management unit,
Autronic 500R High power Direct Fire ignition CDI unit 605 Volts, large
Autronic boost solenoid, six Bosch single-plug coils
Power Output expect 1200bhp, but will never be dyno'd to find out.
TRANSMISSION
All OS Giken unless otherwise stated: four-plate clutch assembly, OS-88
six-speed sequential-shift gearbox with custom-made RB Motorsport-spec
gear-cluster, OS Giken Super Lock limited-slip diffs front and rear, Nissan
transfer box, Nissan drive shafts all through, RB Motorsport Flat Shift
gear-lever kit,Torqline 5.9 kg carbon propshaft.
BRAKES
DBA Skyline GT-R discs and calipers all round
SUSPENSION
HKS Hypermax Drag system all round,Everything adjustable, RB
Motorsport-reinforced rear beam assembly, uprated bushes throughout.
WHEELS/TYRES
Mickey Thompson ET drag radials all round, 26x10.5x16in fitted to standard
Skyline R32 GT-R 8x16in five-spoke rims
EXTERIOR MODS
Radical lightening programme, glass fibre replica doors with plexiglass
windows, VeilSide Drag boot lid with integral low-line rear spoiler,Simpson
Parachute
INTERIOR MODS
Totally stripped-out interior, Bride racing driver's seat, standard R32 GT-R
steering wheel, custom instrument layout with oversized boost gauge and
gearchange light, safety cage,
RB Motorsport mechanical 4wd controller.
So it was you what robbed that bank store in Kent last week was it Keith??;)
I know how to make £2m now!:D
What can I say mate.......simply staggering spec.:smokin:
God I can't wait to see this thing run.:D :D
Keith, simply out of curiosity, so dont get defensive, why will it never have the power measured?
I can understand that times account for more than any power measurment but surely you must be curious to see what it does?
Awesome spec Keith, this baby should motor!!! :smokin:
Simon
Discussion Starter #8
Hi Dave
If we were to run it on a dyno it would not use the same part of the maps
because it would not be under the same load that it is when used in anger
on the road or strip never mind the air temps and air flow.
Plus Rod does not want it to be run on one and neither do i.
Keith
Dyno's can be different, one dyno somewhere can be different to somewhere else, so I think keith is right, not to dyno it and let people guess at the 1/4mile speed,
What weight is your car keith? I used 1400kg with you in it and fuel, and using your 9.3sec run
Keith Cowie: Horsepower Results - 1/4 Mile Method
Your r32 gtr weighs about 1400kg and can complete a 1/4 mile in about 9.3 seconds. That means that you've got about 756.81 HP at the wheels, and about 983.86 HP at the flywheel.
Andy Barnes: Your r34 gtr weighs about 1500kg pounds and can complete a 1/4 mile in about 9.6 seconds. That means that you've got about 737.20 HP at the wheels, and about 958.37 HP at the flywheel.
Norris designs Evo: weighs about 1100kg and can complete a 1/4 mile in about 9.6 seconds. That means that you've got about 540.62 HP at the wheels, and about 702.80 HP at the flywheel.
Quite interesting, and b4 all the boffs start, its just a bit of fun.
Absolutely awesome spec - and thanks for being open and sharing the spec on here - respect for that ..
The engine spec starts off the same as mine ...
keith said:
ENGINE
Nissan Skyline GT-R R32.
... and then is somewhat different after that ..... :p
Hope to see it run in the flesh at a few meetings.
It's always great to see exactly what these cars are capable of.... :smokin:
A few changes then keith :)
How come you are changing to the sm4? instead of the sm2?
Barrie
Discussion Starter #12
Barrie
Hi Barrie
Mark wanted me to fit the SM4 and the high new high power CDI
nothing wrong with the SM2 it is a good unit
Keith:smokin:
Banned
TOTB 5.......thats the business:D
Team Cowie there in force again:smokin:
Plenty of Beer, and another haul of trophies ;)
Better not forget my pompoms :rolleyes:
Have a nice night, Bye now !
:cool:
Banned
looking forward to seeing it run this season keith.
dont forget invite stands for 21st may Scoobyshootout at elvington if you can make it, i've invited a few select cars down for demo runs etc.
rgds
Awesome spec Keith - just one question - are the nissan driveshafts standard BNR32 ones and are they up to the job. At what point do people go for the uprated HKS or similar ones?
Banned
Peter said:
Awesome spec Keith. Have you decided who you are running for at TOTB5 or will you be running an individual tuner car?
Peter, see below........
Jason0 said:
Also for the record, seeing as you're wanting to have a bitching session, I can't recall of you ever making a positive comment regarding the GTR Register or GTROC in any of your propaganda. You get a rather lucrative free ride here Keith, personally I think you should quit moaning at us because you're not that special that we'd miss your input.
Spoken to Keith about his plans for this year, and he has made it quite clear that after a comment like that, and the rather volatile situation of late \ thread about his signature (removed) \ digs about selling T-Shirts when others sell for profit \ digs at the OS Giken sponsorship,he intends to do just whats above.....and have no input regarding TOTB5 for the GTR Register in the future. Probably to see just exactly how much he isnt missed. He wants nothing to do with TOTB 5 selection on here.
Threads like this........
http://www.gtr.co.uk/forum/upload/showthread.php?t=50036
and this.......
http://www.gtr.co.uk/forum/upload/showthread.php?t=48911
...helped him and quite possibly a few others make the choice.
He will be running, thats for sure, but as to who for.....thats up to him......but it wont be the GTR Register. Am sure if he does run for another team though,or as an individual entry, anyone would be more than welcoming of the defending champion as an addition to their team.
Congratulations Keith. That looks like a big commitment and I hope you and the team at RB get the results you're looking for.
Personally I do hope you run for the GTR R as thats why we're all here, even if it can get a little childish at times.
Bye now.
1 - 20 of 86 Posts
