My car currently runs a sard sports cat with the factory temp sensor in place, i am wanting to fit a decat which does not have the space for the temp sensor and was wondering will this prevent the car from retarding the ignition if egts are to high or is it just to detect a damaged cat?
The exhaust temp. sensor has no input to the engine's ecu, it simply operates the warning light on the dash.
If you remove the passenger seat, you'll find the flex.temp. sensor cable ends in a box which can be unplugged and removed.
For a neat finish, the large hole in the floor can be plugged/sealed with a grommet and the job is done.
