Hi!
I have a GTT with 5 gear (manual transmission) and the leverage is too length and slow.
It is possible this is a problem? Or is normally?
And.. how can i fix it?
Thanks!
Ok for short shifter.. But, it is normally with oem gear shift?
The leverage is very soft and "dampish"..
Um, depends what you're comparing it to, remember that 5 speed transmission is the same one used int he 32 and 33 gt-r!
My GT-t's shift wasn't what I'd call long or damp, when compared to, say, my old Corolla Levin. However compared to my ex's S2000 or my GT-r then yep, definitely soggy!
The short shifter should improve this (if you need it improved) but other than that there wouldn't be much you could do to help - maybe a bronze shifter spigot could help the feel but remember, the GT-t is more of a cruiser than the r's are so it's designed to be a bit softer :)
