1 - 18 of 18 Posts
The Workshop
Welcome to the workshop! Here we'll keep dropping in so you can see what we get up to on a daily basis, get in touch with any specific queries (details in the sig below) or post in the Q'n'A thread and we'll try and help!
Thank you!
AC
  • Like
Reactions: Tinyflier
Discussion Starter #2
Photo by ACspeedtech in ACspeedtech. Image may contain: indoor
Another delivery of nice fresh VR38 engine blocks for some big power builds coming soon!
Just brings the geek out in you doesnt it!
Discussion Starter #4
Happy Friday all! Nice new IC-7 dash 'with extra love' from #haltech
Photo by ACspeedtech in ACspeedtech. Image may contain: car, sky, cloud and outdoor
Transmission repaired and calibrated, ABS system repaired and calibrated... Next!
Discussion Starter #6
All calibrated up and canbus data streaming per cylinder knock and threshold knock events. Awesome piece of kit. Highly recommended! Anyone interested please get in touch for pricing!
Discussion Starter #7
Huge thanks to Mike and the chaps @extremeturbosystems for putting this big order together for us! Been a difficult one in this current climate but they've looked after us really well as always, cheers guys! (y)
Discussion Starter #8
Photo by ACspeedtech in ACspeedtech. Image may contain: outdoor
Sometimes there's no easy way to test a few products and theories, buy a fuel tank, cut it open, power it up... @asnu_fuel_injection
Discussion Starter #10
Any pricing queries please drop us an email, with exchange and shipping rates varying we would need to give a current price for which parts you're after (y)
Discussion Starter #11
ACspeedtech R35 GTR fuel pressure sensor kit now available!
Bolts directly onto OEM fuel rail, supplied with a 0-150psi sensor and wires into one of the spare 0-5v ecu inputs.
We recommend using the bank 2 boost sensor input as normally not used when on an SD based remap or the SAS maf input as normally removed on high power builds.
Includes full wiring guide, optional ecu input guide and even instructions for setting up and calibrating the input within the Ecutek racerom software so no excuses from your tuner! 😁 The cost is £275+vat/shipping.
Get in touch for orders and any other details!
261836
261837
261838
Discussion Starter #13
Are you going to do a plug and play option ?
If we do then it makes it specific to using the SAS maf, AFM or Boost sensor input to the ecu. We are expecting some of the male boost sensor plugs so can have that as an option. In the meantime it's just 3 wires to connect (y)
Discussion Starter #15
It would be good option , so it makes things reversible. Combined with the SD kit , better than ordering everything from the USA.
We would normally just piggyback onto the wires at the boost sensor plug so its 3 snips and some insulation tape away from oem but yes, a lot of people without soldering equipment obviously will be easier for them!
The 'SD' kit... factory sensors run up to 1.7 bar so if you're under that you just need a high speed air temp sensor wiring in and fitting into the upper boost pipe, £60 sensor and 30 mins to fit. we normally just say £100 fitted. Over 1.7 bar you obviously need the higher scaled MAP sensor fitting into the inlet manifold.
  • Like
Reactions: UKPAISLEY
Discussion Starter #16
Out with the old, in with the new, G35-900 on a nice new single turbo manifold and Turbosmart wastegate. Rb26 into the new world of turbos!
Discussion Starter #17
261958
261957
Uprated larger ACS intake kit and Ecutek custom map tweak to suit improving the breathing at higher rpms over the oem airboxes 👍
  • Like
Discussion Starter #18
262042
Not a GTR but... Awesome Porsche 718 GT4 in for a chassis and alignment setup, never get tired of driving these and with a few tweaks transforms the handling over stock!
1 - 18 of 18 Posts
