Corky bell was and is american.
Not sure o that one. I have two guesses here.
1. that those variables might be incorporated into that figure of 1.5. perhaps super effiecient breathing will chnage that value and at the same improve volumetric effiency beyond 85%., have to consider other things that will be off direct significance such as air temperature too,this will almost certainly lower this value.
2. there is a quote which says that cubic capcity has nothing to do with how much power your engine has, only at what rpm it achieves the power that it does.
if power comes only from oxygen which it does, then a bigger engine means that per minute it can consume x volume of oxygen, if you double the rpm it will consume 2x, if you have the engine capacity it will consume 0.5x.
so a two litre at 8k consumes the same oxygen as a 1 litre at 16k which makes complete sense.
If power per stroke is therefore only dictated by how much oxygen you can get into the cylinder,anything that will make this easier should increase power, ie porting, polishing, longer duration cams, higher lift, higher boost pressure.
All these will do is make sure when you think your cylinder is full, that it really is full and at the pressure you think the turbo is providing. In essence improving the efficiency of the engine to act as a pump. Since I am working this out in my head as I go along, I think this in essence is just the same as point one, ie. it gets incorporated into volumteric efficiency.
Troube volumetric efficiency is a bit of an anomoly on a forced induction car this there is always positive pressue in the manifold due to the turbo charger (or supercharger).
makes it a bit more difficult to understand, for me at least.
It also explains why things such as porting and polishing are not as important as they are on normally aspirated cars, I suppose effectively the turbo rams the air past the restrictions in the intke path, so these restrictions are not as significant. they will however create more work for the turbo meaning the charge will be hotter.
who knows?
anybody else care to add their take on it?
who knows?
