1 - 20 of 41 Posts
Hi All,
I'm thinking of splitting my 32 as I'll be selling it anyway and its currently an unfinished project and I don't really have the time to finish it.
I'm awaiting an OS Giken Bearing Sleeve for the clutch system which means I can't finish it, currently the box is off the car so it could be a good time to split.
Basically I'd be looking to sell it in chunks as follows;
1. R34 N1 Nur Engine complete approx 22,500 miles
Gold topped engine Includes throttle bodies/plenum/Trust Sump extension/Nismo 600cc Injectors/Tomei cam pulleys/HKS cams/N1 Pistons/Rods/Crank/N1 oil and water pumps, fully balanced and hand built from factory engine. Also included are RBM AFM's and Apexi Power FC ECU and Commander so its a drop in package. Sump has R32 front diff fitted.
Looking for £6.5k for the lot.
2. R32 1990 GTR complete car less Engine/exhaust and Box
Rolling chassis includes Volk LE37T 17" Alloys Good Bridgestones all round, Brand New Nismo S Tune HA Suspension fitted, Brand New HKS Kansai 7 Point Roll Cage Fitted, Adjustable front Tension Rods, new battery, no rust whatsoever, excellent condition except bonnet which has some laquer peeling and rear nismo lip on boot spoiler which has blownand cracked. No dents, no stone chips, mint otherwise. N1 front bumper and bonnet lip. Ideal base project car, has all brakes/fittings/Rad/Intercooler etc.
Looking for £6k. (Rollcage is over 1.2k, suspension is like £1.5k etc both brand spanking new.)
Regards
Nito
Nito you dont have an oil cooler and relocation kit sitting about do you? also im looking for some down pipes...ive noticed your not selling the exhaust system but i thought id ask anyways....any info you can provide would be appreciated
The cage didn't come with instructions, it wasn't too difficult to figure out assuming you've got all the brackets and bolts. Basically three bolts per fixing and the plate goes on the underside of the car. Fit the rollover hoop first then the rear and front bars.
I have an oil cooler and exhaust system but won't be listing them unless these go first. Otherwise I'll complete the car and sell it as a whole.
Nito
Forgot to add, Nur engine comes complete with N1 Turbines.
Picture of it in the 34
Pulled out the 34 before cleaning/refitting (also now has HKS TB and Intake manifold gaskets)
Work in progress
The 32
Nito
Hi Guys,
I've had a few pm's. I haven't been clear, I'm looking to try and sell this in large chunks as in the car without engine/box etc and the engine complete as above. I also have a Giken seq box with interested parties unless I can place all of the above though, I'll be finishing the project.
I'm not looking at breaking it into lots of parts, the idea is to minimise workload as I'm time poor at the moment. I only need a couple of silly small parts related to the clutch mechanism to complete it and the engine is already back in but these bits tend to take a while to arrive!
Thanks again, I think it was a bit of a flyer on the off chance that anyone was after any chunks for a project.
Nito
Discussion Starter · #9 ·
Neeltec,
It was running in the area of 530bhp as estimated by Rod Bell in the current spec with N1 turbines at 1.3bar. The engine should be good for 600bhp with reliability with the right turbos. I believe Peter has been running this sort of power for a while. It also has the trust sump with extended pick up so will not suffer oil surge.
Nito
hi mate, just looking for rolling shell if ya get stuck, prob with cage in though, thanks
Discussion Starter · #12 · (Edited)
Looks like the car will be splitting pending the sale of the engine and box which are currently spoken for.
All parts for R32.
Engine
Complete Nur Engine £Prov Sold
HKS Oil Cooler Type R with Filter Relocation Kit BNR32 £450 (Brand new)
Titanium Exhaust System £300 (Custom System, used)
Aftermarket Frontpipes £100 (used)
Apexi Super Suction Kit for 80mm AFM's £250 (Lamb)
Apexi AVC-R Boost Controller £150
Field One touch Harness Connector £100
Nismo Turbo Outlet Intercooler Pipework £Prov Sold
Nismo Rad cap £15
Nismo Fuel Pump £300
ARC Air Remover Kit and Swirl Pot to fit stock rad £250
Transmission
ATS Carbon Twin Plate Clutch (1350 Pressure Plate 900ps) £1350 ( Brand new)(prov sold)
OS Giken Sequential Gearbox (OS88 Series 2) £Prov Sold
Chassis
Volk LE37T 17" Alloys - 245/45/17 Bridgestones £800
Nismo G-Attack S Tune HA Suspension £1350 ( Brand new/currently fitted)
HKS Kansai Strut Tower Bar £300 ( Brand new)
Endless Hicas Breaker Conversion £100 ( Brand new)
Field ETS Linear £250 ( Brand new)
Nismo Braided Brake Lines £100 ( Brand new)
Bodywork
RK Tuning Replica Nimso Rear Boot Lip grp £80
Interior
HKS Kansai 7 Point Roll Cage £
Defi MeterControl Unit II £55 ( Brand new)
Defi 60mm Boost £80 ( Brand new)
Defi 60mm Fuel Pressure £100 ( Brand new)
Defi 60mm Exhaust Gas Temperature £100 ( Brand new)
Defi 60mm Oil Temperature £80 ( Brand new)
Defi 60mm Oil Pressure £100 ( Brand new)
Defi 60mm Water Temperature £80 ( Brand new)
Defi 115mm Tacho £120 ( Brand new)
Defi VSD Speed/Revs Head Up Display £200 ( Brand new)
Greddy Turbo Timer £50
Momo Race 350mm Steering Wheel £140 ( Brand new)
Miscellaneous
Coil Packs £100
Greddy 8 Plugs £50 ( Brand new) (Lamb)
Coil Pack Loom £50 ( Brand new)
Ignition Amplifier £100
Lambdas £40
RK Tuning Nismo Replica Lip £80
Redline Oil Shockproof Heavy 5 Litres £80 (Lamb)
Full car:
(excluding Engine/Box/Exhaust/Alloys/Suspension) But including Brand new HKS Kansai 7 point roll cage, HKS Kansai Adjustable Tie Rods, steering rack, subframes, rear diff, full interior, Lights, Glass, Intercooler, Radiator, doors, boot, bonnet, spoiler, side skirts, excellent brakes etc etc, all in very good - excellent condition. Ask for full details. The Chassis will not be mobile unless purchased with alloys/suspension listed above and will need to be collected. Currently on Axel Stands. I have jacks engine hoist to aid with lifting onto flatbed etc. £3995
All of the above excluding postage and not open to offers at the moment. If you're interested please pm me and put your name next to the item(s) so I can pm you when they become available.
Regards
Nito
what style face do the defi's have, mine are non BF style with a black face, if yours match ill take the oil pressure.
Discussion Starter · #17 ·
inFocus
They are the same as yours, black face green illumination.
Nito
Discussion Starter · #19 ·
Update
Update on parts prov. sold.
All parts for R32.
Engine
Titanium Exhaust System £Prov Sold
Aftermarket Frontpipes £Prov Sold Geordieboy
Apexi Super Suction Kit for 80mm Z32 AFM's incl. connectors £250
Apexi AVC-R Boost Controller £Prov Sold P3RV3RT
Nismo Rad cap £15
Transmission
Chassis
Nismo Braided Brake Lines £Prov Sold Tarmac Terrorist
Bodywork
Interior
HKS Kansai 7 Point Roll Cage £900 (Brand New)
Defi 60mm Oil Pressure £Prov Sold inFocus
Miscellaneous
Coil Packs £100
Greddy 8 Plugs £Prov Sold
Lambdas £40
RK Tuning Nismo Replica Boot Lip £80
Full car:
All of the above excluding postage and not open to offers at the moment. If you're interested please pm me and I'll put your name next to the item(s) so I can pm you when they become available.
Regards
Nito
Discussion Starter · #20 · (Edited)
Now Splitting
Car is now Splitting.
Engine
Titanium Exhaust System £Sold
Field One touch Harness Connector £100 (new)
Nismo Turbo Outlet Intercooler Pipework £Sold
Nismo Rad cap £Sold
Nismo Fuel Pump £300 (Brand new)
ARC Air Remover Kit and Swirl Pot to fit stock rad £250 (Brand new)
Transmission
R34 Twin Transmission Coolers and pumps £Sold
Chassis
Nismo G-Attack S Tune HA Suspension £Sold ( Brand new/currently fitted)
Nismo Braided Brake Lines £Sold Tarmac Terrorist
Bodywork
RK Tuning Replica Nimso Rear Boot Lip grp £80 (new)
Interior
HKS Kansai 7 Point Roll Cage £900 (Brand New currently fitted to shell see below)
Miscellaneous
Coil Packs £100
Greddy 8 Plugs £Sold
Lambdas £40
Nismo Veruspeed Oil Filters 3 remaining £15 each
HKS Kansai BNR34 Titanium Exhaust 80-90mm 600ps (work of art over 2k to buy new 2000 miles use as new) £1350
R34 GTR Airbag Steering Wheel £150
Stock R32 Turbos incl. manifolds £300
Blitz Induction Kit BNR32 to fit stock afm's £80
Full car:
Excellent condition Shell (no damage) (excluding Engine/Box/Exhaust/Alloys/Suspension) But including Brand new HKS Kansai 7 point roll cage, HKS Kansai Adjustable Tie Rods, steering rack, subframes, rear diff, full interior, Lights, Glass, Intercooler, Radiator, doors, boot, bonnet, spoiler, side skirts, excellent brakes etc etc, all in very good - excellent condition. Ask for full details. The Chassis will not be mobile (on axel stands unless wheels/dampers supplied) and will need to be collected. Currently on Axel Stands. I have jacks and engine hoist to aid with lifting onto flatbed etc. £3995
All of the above excluding postage and not open to offers at the moment. If you're interested please pm me and I'll put your name next to the item(s).
Regards
Nito
1 - 20 of 41 Posts
