1 - 10 of 10 Posts
Just wondering if I should be happy or expecting more from my 0-60 and 0-100 times. They seem ok going by the vbox table Jamiep has made.
O-60 3.28s
0-100 6.72s
Times were done with none of the aids off and using manual gears
Assuming you have EcuTek traction control, why not test using that (RCTC)?
Did you launch?
Protegimus
Ambient conditions, road surface friction, gradient (2.5% slope is the max allowable, I believe?) all can add up to make a big difference in times.
I still think the best indication of outright power is probably the terminal speed at the end of a quarter mile, that is usually very comparable on similarly powered vehicles.
Yes, EcuTek requires transmission: R, suspension: C or whatever you want, traction control: off [TC] - so in the 100 map you'll have EcuTek Traction Control.
It's worth about 3/10 on a CBA from JV's testing.
Good luck!
Protegimus
Catch up with Mr. Litchfield, lots of new toys for you!
Protegimus
1 - 10 of 10 Posts
