Right, on my r33 gtr my throttle position sensor is faulty.
The AWD light keeps coming up on the dash and the ATESSA system reads fault code 75 - Throttle Position Sensor
The clip itself is broken so doesnt hold in properly but the problem it seems is actually the wires coming out the back of it, if you wiggle them the light goes off.
This is only a temporary fix though and hit a bump and it goes back to AWD. This is a big pain in the backside.
How easy is it to fix this problem?
Can you just take the plug apart and reconnect the wires? Or is it a swap out job?
