81 - 100 of 110 Posts
Discussion Starter #81
Looking good mate, can't wait to get mine on the road and up to gary for a remap! What ecu did you use?
Thanks mate, yeah certainly knows how to map a car!
Just an Apexi Power FC running map sensors as it's single throttle body.
Ah ok cool that's what gary has told me to get but the maf version, just about to start collecting parts over the winter to get it all done early next year. you will have to come along when i go up there so i can check out your 32
Discussion Starter #84
Yes mate no problem, I'm local to Gary so will pop over for a cuppa.
I've got a few parts too so I'll keep my eyes peeled if you need something.
Great results mate! Who mapped it?
Gary at AP Tuning
Could you please post your full engine spec including any additional machine work which you had done?
Very nice results for that spec! Did you have any work done to the head?
Discussion Starter #87
Was planning to do that, just wanted to get the final mapping done first before I put it all together.
Discussion Starter #88 (Edited)
New specification!
Don't think I have missed anything.....
Garrett 2860R -5 turbos fully rebuilt and balanced with new internals by Turbo Dynamics
Modified manifolds with ceramic thermal coating by Charged Coatings LTD
Manifold heat shields, turbo elbows and boost pipes also ceramic thermal coated by Charged Coatings LTD
Block bored and honed
Head fully overhauled
Nismo 0.9mm metal head gasket (GT500 spec)
Nissan full engine gasket kit
Tomei head oil gallery restrictor
Tomei 260° cams
Os Giken adjustable cam pulleys
Nissan N1 oil pump
Nissan N1 water pump
Nissan crank shaft - balanced with flywheel
Fluidampr crank pulley damper
Tomei sump baffle
Wiseco 87mm forged pistons - balanced
Bridgeway Forged I Beam rods - balanced
ACL HX Race bearings
ARP head bolts
ARP main bolts
ID 1000cc injectors
Aeromotive 340 in tank fuel pump
Tomei fuel pressure regulator
Trust intercooler kit
Greddy full intercooler hard pipe kit
Custom one piece intercooler to throttle body pipe made by Andy Cater at AT M Engineering
RIPS intake manifold with 90mm single throttle body
Nitto metal intake manifold gasket set
S14 throttle cable
HKS 90mm downpipes
Turst Power Extreme 2 Exhaust
New o2 sensors
Splitfire Coil Packs
NGK Iridium 7 spark plugs
Trust Alloy Radiator
Trust suction kit and mushroom air filters
HKS Oil Filter
Millers mineral oil (for running in period)
Millers CFS 5w40 fully synthetic engine oil
APexi Power FC D-Jetro ECU
APexi boost control kit
Mapped by Gary Hayward at AP Tuning
1 bar - 501hp
1.2 bar - 554hp
1.4 bar - 602hp
Just shy of 450lb/ft @ 6000rpm
OS Giken gear kit
Nismo Super Coppermix twin plate clutch
Braided clutch line
Alcon 365mm front brake kit with Ferodo DS Uno pads
Brembo R33 rear brake kit with Ferodo DS Uno pads
Cusco brake stopper
Braided brake lines
Tein Super street coilovers
Nismo reinforced engine and transmission mounts
Nismo top links
Nismo front and rear anti roll bar kit
Nismo rear bush set including subframe
Driftworks Hicas eliminator kit
Front and rear strut braces (rear is Cusco front is unknown)
SuperFlex Wishbone Bush Kit
SuperFlex Caster Bush
Ultralite ATec 18x9 alloy wheels
Toyo 888 tyres 265/35
Work open ended racing wheel nuts
4 wheel laser alignment and geometry by AP Tuning
Recaro reclinable bucket seats
Greddy Exhaust Gas Temp Gauge - A pillar
Greddy Boost Gauge - A pillar
Momo steering wheel and boss kit
Battery relocated to the boot
Nismo N1 intercooler vents in front bumper
Nismo oil filler cap
Nismo solid shift kit
Nismo aluminium shift knob
Nismo front and rear carpet mat set
Nissan aluminium brake and clutch pedals
Carbon cooling panel
HID headlights
SFS Silicone hoses
Discussion Starter #99
Get a mate to do it on a phone, getto style! :D:D
Ha ha ha like a proper hoon bag!
Someone I know has got a GSi Astra with a 500hp vxr engine in, might ask him to film the tail lights for me :chuckle::chuckle:
