Hey Guys & Gals
I'm thinking its time to start rebuilding my RB. I've been reading through a lot of the rebuild threads looking at the shiny parts everybody else fits and I've compiled a spec list, but I think I may have gone waaaayyyy over the top.
I am after a car I can drive every day to work (A & B roads, some traffic), weekend use, very occasional track (maybe 1-2 times per year, don't know yet never been on track). My driving style is a little conservative, sometimes I just drive nice and easy and hardly come on boost, other days I may feel a little more spirited. Some days I have to follow a tractor, other days the roads will be clear.
Not looking for big hp, but maybe a little more than current. I would like to get a nice responsive build, especially at the lower rpms which would (for example) help 30-40mph accel.
The biggest dilemma I face is whether to get forged pistons. I know they are stonger, lighter, run more hp etc... but I also know they are for "race" use and when run cold will slap the cylinder walls and shatter the rings. They are also expensive.
If I was to go for forged pistons I guess I would be better off with a 2.8 stroker? I'm guessing that this (with mods listed below) net me to about 600-650hp. Can/do people run this every day in traffic etc, or is this spec more for weekend/occasional use?
I don't mind the rattle when cold as long as it isn't going to damage anything. I'm not a mechanic but as far as I see it noise = vibration = damage. I guess forged also use a lot more oil? Again not a problem if no damage will be caused. What does it take to get these to operating temperature? Do I just drive easy until the oil temp comes up same as I do now?
What are forged pistons/stroker kits like to live with on a daily basis is the main question I guess?
If I don't use forged pistons, what are the Nismo N1 pistons like? Stronger than stock, but not as strong as forged? Stock reliability.
Anyway, this is my current spec list as it is at the moment:
HKS Super Racing Intakes
HKS Mild Steel Downpipes
Sports cat
Veilside Titanium "Teardrop" exhaust
Baffled Twin Turbo Pipe
HKS 1/2 Hard Pipe Kit
HKS R-Type Intercooler
Tein Monoflex Coilovers
Nismo front strut brace w/ brake cylinder stopper
Nismo brake lines
DS2500 Pads front / std rear
DBA Discs all round
Panasport racing alloys (275 all round)
Greddy Profec B spec II boost controller
Greddy Aluminium radiator
Unknown clutch (will find out when the engine is removed)
Cusco Hicas delete kit
Cusco Front camber arms
Exhaust temp gauge
With the exception of the engine internals covered above, this is a list of other parts to be fitted during the rebuild.
Balance existing crank with std rods and N1 pistons
ATI Crank Damper Pulley Kit
Nismo Gasket Set
Tomei High Flow Oil Pump
Tomei Sump Baffle Plate
Tomei Oil Gallery Restrictor
Tomei Oil Line Restrictor
Sump extension (can these be got without lowering ground clearance)
Nismo N1 Water Pump
Tomei Poncam Camshafts
Adjustable Pulley
Kevlar cam belt
SplitFire Direct Ignition Coil Packs
Tomei Turbine Outlet Pipes
HKS GT-SS Turbo Upgrade
High flow fuel pump
Injectors (don't know what capacity)
Adjustable Fuel Regulator?
APEXi Power FC D-Jetro
Oil catch tank
I know I need other little bits n bobs like head bolts, bearings etc... but is there anything big I have missed or should upgrade as well? Anything else while the engine is out?
If I am forking out for a stroker kit (or even forged pistons/rods) then I will probably leave the GT-SS for a later date. Is a turbo upgrade an engine out job? This will effect my decision.
Abbey Motorsport will be doing all the work so the final list will be down to them. I'm just trying to get a clearer picture of what I need/want so I can let Mark know.
What would the mpg be like with this kind of setup? Currently doing about 20-23mpg (370-400km to a tank) which perfectly fine, I can (and do) live with this. I don't really want something that only does 8 to the gallon or anything silly like that.
Thank you for any and all help and guidance you can give me. This is a one time only job and I really want to get it right first time.
Many thanks
Tim
Sports cat
Nismo brake lines
DBA Discs all round
Exhaust temp gauge
Nismo Gasket Set
Nismo N1 Water Pump
Adjustable Pulley
Kevlar cam belt
High flow fuel pump
Oil catch tank
Many thanks
Tim
