This is the set up I have and its very good!Just fitted 400mm Alcon fronts, 380mm rears with Pagid RS29 pads.
20k miles on original OEMs. Pads less than half worn, only 1 small crack on the OEM pads. Pads were pretty glazed to be fair.
Only just bedded in the new anchors but I'm gobsmacked just how good they are. Car now feels it needs more power as the brakes just scrub off massive speed instantly.
Very,very impressed. Wholly recommend.
Satan
How did you bed yours in? I just went out and did 3 medium stops and 3 hard / heavy stops.This is the set up I have and its very good!
How much was this set up mate?Just fitted 400mm Alcon fronts, 380mm rears with Pagid RS29 pads.
Satan
To be totally honest mate I bought them through work over 2 years ago so I don't have the receipt and at my age memory not so good!!!How much was this set up mate?
A year ago I paid just under 3k including VAT and fitting for this set up.How much was this set up mate?
Out of interest, how many miles have you done on them and how is the wear on Discs and Pads please?A year ago I paid just under 3k including VAT and fitting for this set up.
the same really but they were heavy stops!!How did you bed yours in? I just went out and did 3 medium stops and 3 hard / heavy stops.
Following day just used as normal. Only have a 100 miles on them so far.
Satan
Ive done some 5k road miles since they were fitted a year ago and the Bruntingthorpe Asda day which is very hard on the breaks, still plenty left on the discs and pads. I recon with similar annual use they should last me another 2 years at least.Out of interest, how many miles have you done on them and how is the wear on Discs and Pads please?
Satan
I was hoping with everyone saying the original discs were soft that using the supposedly kind RS29 pads that we would get a bit more than that!Ive done some 5k road miles since they were fitted a year ago and the Bruntingthorpe Asda day which is very hard on the breaks, still plenty left on the discs and pads. I recon with similar annual use they should last me another 2 years at least.
I may get more they may do 30K road miles, the discs look like new and the pads have plenty left on them after 5k miles and a track day. Another 2 years was a real guessI was hoping with everyone saying the original discs were soft that using the supposedly kind RS29 pads that we would get a bit more than that!
Not a cheap do these 35's!!
Satan
Oh thank fu*k for that!!I may get more they may do 30K road miles, the discs look like new and the pads have plenty left on them after 5k miles and a track day. Another 2 years was a real guess
