1 - 11 of 11 Posts
I have for sale, a Tomei RB2.8 stroker short block.
N1 24U block
Tomei 2.8 stroker kit, 87mm recessed pistons (for valve clearance)
titanium piston ring kit
ACL race bearings
HKS oil pump
New rear main seal installed
New pilot bushing installed
Trust sump extension already welded to stock sump and includes front diff can provide picture if required. (not installed on short motor)
I have receipts from Cambridge re-bores for 770GBPs. No expense spared.
Crank balance checked and balanced to higher tolerance
Journals polished
Bores machined to individual pistons
Rings file fit to each bore
Rods balanced end to end
Rods big ends honed
Block cleaned and inspected
Block line honed
Block clearance for longer throw crank (see pic 4 area near oil squirter)
Deck re-surfaced
Sump mating area surfaced
New core plugs installed
Block painted
Short motor is assembled with all measurements taken.
Motor is as assembled, oiled and wrapped on engine stand. Can be viewed for inspection.
Have 6K+ invested, asking 4800GBPs ovno.
Please no silly offers, as I do not need to sell. Only selling due to a change in project direction.
Sorry Ron!! lol. Might end up using it, but have another project in the works, so this will be sitting for a bit.
b****rd heeeeee heeeeee heeeeee :chuckle:
nice kit nate buddy. if i have the extra money ill snap it off your hands without having second thoughts :bowdown1:
what setup are you thinking now? you seem to change your setup as easy as changing clothes! :)
hope you are well and good buddy :thumbsup:
Discussion Starter · #9 ·
Thanks asiasi,
Tomei rates the kit to 700+, but that is a conservative number set by a manufacturer for warranty purposes. The motor has been built with larger piston to bore and ring clearances for higher hp, but not by much as the Tomei pistons do not expand like CP and the likes. Motor will do 1K hp without being a "breather" or having cold start piston slap.
1 - 11 of 11 Posts
