1 - 17 of 17 Posts
Looking to purchase a front led emblem and rear led side markers, is there any one or company in the Bedfordshire/Hertfordshire area who can assist in fitting?
Dan
Autotorque (forum trader) maybe able to help on fitting etc, and not too far, Barry and John have used for thier R35s.
Lee fitted my front and rear TK bades with no issues at all. Give him a shout if you fancy, he is based near Gatwick (South).
H
H
What's involved in the fitting process on the front one?
As far as i know... not much. It's a direct replacement, so its just wiring which I believe Lee wired into the sidelights. Low current draw so you could probably just piggyback in to existing wiring without any concerns. Best bet is to ask Lee as he would know precisely what's involved.
H
Just connect direct to side lights done mine this morning, it is very tight with the wiring as you cannot actually pull the wires free, but done it by adding more length to them, now when sidelights are on the GTR emblem lights up, it really is that simple to fit.
Bobby
Bobby
sounds good, so no need to remove the front bumper?
All you need to remove is the front slam panel of which is just held on by the plastic clips, the connector for the side lights is the one on the top of the headlamp of which just twists and then comes out.
Bobby
Bobby
Many thanks sounds simple enough, do you need to do any soldering or is it plug and play?
That's awesome mate, where can I get that R badge? So you connect to the side lights and that's it right? Do you need to earth it or anything? Cheers ben
Looks cool I'm quite tempted.
If anyone interested, we have a few more again in stock
Illuminated side sills, and side indicators are available too
1 - 17 of 17 Posts
