1 - 11 of 11 Posts
Hi all... Do tracking all day long on Ford's with lazer tracking (not geometry, just toe adjustment..) - realise its not the best for such a beast as the skyline but generally can get them going straight..
When set her up, didnt have spec to hand, so set the car up parallel... n well, she dont like it much...
Have since checked spec in workshop manual which specifies 1 to 1 on the front and 2 to 2 on the rear...
On fords we normally get a spec, ie, -1 to +1 meaning parallel or 0 to 2, meaning set to 1...
Are skylines that specific it has to be toe out to +1 at the front and toe out to +2 at the rear with no give or take specification ?
Taken from a previous post.
Front
Camber[deg]-0 50,+/- 45
Caster[deg]3 55,+/-45
Toe In[mm]0 ¬ in 2
Rear
Camber [deg] -1 15 +/-30
Toe In [mm] in 4¬0
It doesn`t make much sense to me but it may help you, i hope.
Discussion Starter #4
ah cheers, dont get the little symbol between 0 and 2 or 4 to 0...
is that front spec of
0 to +2
and rear of
+4 to 0?
n e able to shed some light ?
technically that would equate to +1 @ the front and +2 @ the rear, which is what i 'think' the workshop manual spec is... Cheers
If i remember correctly DCD posted it a few years back and i thought it would be a good idea to write it down for "future reference" .
Maybe if you PM DCD he will have more info.
Looks
Like Zimmer frame data to me Pete. LOL
Still when you are 50 is suppose it becomes relevant.
Tony:) :) :) :)
Now Then
Yunis A said:
Tony expect a visit soon, I need the full tracking done:)
Just got to get the rear subframe bushes done first.
Thats something to look forward to LOL:) :) :)
Tony
Have you fitted the shocks yet Yunis?
Saw your other pics, you'll have to let me know what they're like with the damping made softer and softer springs.
Nito
1 - 11 of 11 Posts
