There is a US Service bulletin NTB09-124 for 2009 – 2010 GT-R Transmission side oil seal leaking.
Never heard of this before on any of the forums so suspect it is very few cars, but worth getting the HPC to confirm everything is OK when serviced.
Just the seal is changed not the whole transmission....
http://x.nissanhelp.com/forums/Knowledgebase/links/545
Paul
This isn't a scheduled service item...instead it is Nissan showing a little common sense. Previously if the driveshaft seal in the transmission started to leak, the whole transmission had to be replaced. Now if the seal leaks, just the seal will be replaced.
The same bulletin should be released in Europe in the next week or so.
