1 - 8 of 8 Posts
Is your gearbox seeping oil from around the top where the gearstick goes in?
If it is this might help looking at Nissan Fast these were fitted to the gearbox on N1 models to stop oil splashing up and seeping around the top of the box. If yours isn't would seem pointless.:thumbsup:
It stops transmission fluid seeping out due to high cornering speeds etc.
I had a bit of seepage so fitted one and it does appear to help.
i have one of these exact items fitted. the main reason they seem to work is the gear lever does not go into the gearbox,but the trannsfer box, that has atf fluid in there and a very large chain spinning around, so the combination of hot thin oil and the chain to throw it around is why the leakage often occurs.. so yes this will help.
1 - 8 of 8 Posts
