the following is quoted from gtrowner.com
"The transmission is considered to be the weak point of the Skyline and is very costly to replace if it goes wrong. The Baulk rings within the gearbox grind when changing gear, generally when changing down. The gears most prone to wear are Fourth and Fifth and this can be checked by changing up from third to fourth at high revs. When test driving the car, you will need to take it on a motorway and change gears quickly to notice if there is any grinding. The transmission has also got to cope with the power split between the front and rear axels. Nissans name for this is ATTESSA, so look out for any warning light on the dashboard to indicate any problems with this, but it is generally very reliable."
This is happening to me........when changing from 3rd to 4th at high rpm, i'll hear some noise from the transmission....
pls. adv. how to get rid off that noise or which part of the transmission is not working. it's been like that since a month ago and i tend to shift slower when changing from 3rd to 4th.
michael
michael
